Signal and flasher problem on 96 2500 Cummins
Old Aug 20, 2017 | 08:12 PM
Cannonball60's Avatar
Cannonball60
Correct buddy! None of the afore mentioned fuctions including the brake lights work without that button depressed. But depressing the button does nothing for the 4 ways and that's its sole pupose???
Old Aug 20, 2017 | 08:34 PM
That's weird.
Check and see if you are getting power where it should be at the brake switch. (you can get a FSM from here. Wiring diagrams are in section 8W.)
Old Aug 20, 2017 | 09:08 PM
Cannonball60
Thank you buddy I'll have to check tomorrow because mylighting is limited but I will scrutinize that manual though!! I'm still really baffled as how the negative lead feeding the power distribution box is hot?? And at the alternator too! I read a full 12 volts from ground to ground. Thanks again and I greatly appreciate the time you're taking to help me.
Old Aug 20, 2017 | 09:32 PM
No negative lead on the PDC. The wire from the alternator to the PDC is power feed.
Old Aug 21, 2017 | 04:13 PM
Cannonball60
Well that's a relief to know that lead from the alt. is supposed to be hot. In answer to your brake light question, I have power to only one contact at the very end of the harness connector. With or without the the key on if that helps. Thank you again!! Also I checked all other terminals with the key on and signal indicators activated and got nothing.
Old Aug 21, 2017 | 07:26 PM
Does the third brake lite work?
have you check fuse 3(40a), and fuse C(15a), in the PDC?
also, fuse 6 in the side of the dash. (test this one, even if it looks good.)
Are you getting power to the turn signal flasher?
Old Aug 21, 2017 | 09:16 PM
Cannonball60
I checked the two fuses in the PDC that you mentioned and they are both good. I will do further dianostics within the interior fuse panel thanks again Hey You, you're terrific for helping me because I'm stumped. This truck does have a factory towing package and I haven't checked the trailor connections yet but I will. At least with the hazard button depressed all directionals work inside and out so the trailor lights can be tested also.
Old Aug 22, 2017 | 10:18 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Will say this in my 96 I had no turn signals (everything else worked) turned out the LEFT terminal for the flasher came loose. You have power going somewhere it shouldn't, or a bad ground and the switch is grounding all the lights out instead of the 4 ways like it should.
Old Aug 22, 2017 | 06:58 PM
Cannonball60
Thanks, MoparFanatic. I just discovered today that I have no power to the Fuse C(15a) in the PDC that HeyYou told me to check. I previously checked that fuse but didn't check for voltage like I should have. I have removed the PDC cover to expose the wiring underneath but cannot find any obvious problems but tomorrow I will scrutinize everyground in the vicinity because I know what havoc a bad ground can cause! Thanks, for your input all help is greatly appreciated!
Old Sep 14, 2017 | 07:19 PM
Cannonball60
Default Signal and Flasher problem on 96 2500 Cummins
Problem solved. I had no voltage to the Fuse C. I crimped an eye fitting on a short jumper from the power lug and fed power to the fuse and the ciruits work fine and still are fuse ptotected as well Thanks for all of the help!!
