1999 Dodge Ram 2500 V10: Diagnosing lack of power issue
Old Sep 21, 2017 | 03:57 PM
portlandv10's Avatar
portlandv10
Default 1999 Dodge Ram 2500 V10: Diagnosing lack of power issue
It sat for about a year, had very little gas in it, and now runs 92 octane. Drove it for about 400 miles.
Definitely know I have an exhaust leak.
In any case seems severely underpowered, and read through some posts regarding injectors needing to be replaced and or fuel pump/filter.
I have a scan tool (Bosch), any way of diagnosing if i have lean condition?
Old Sep 21, 2017 | 04:17 PM
See what the O2 sensor has to say. Also check long, and short-term fuel trims.
Any misfire codes?
Old Sep 22, 2017 | 12:36 AM
adukart's Avatar
adukart
Is it like this video? I haven't seen this guy on here in awhile but he was a Mod at one point.
Old Sep 25, 2017 | 09:53 PM
2bit's Avatar
2bit
Can't figure out how to delete post. I was in a different thread, no idea why it posted here.
Old Sep 26, 2017 | 12:17 PM
portlandv10
Update,
Upon scanning my truck, i discovered that the governor pressure sensor shows high voltage as does a code for the trans temp sensor voltage.
Is the temp sensor part of the governor pressure sensor. Upon some research I thought I recall it is, and you have to drop the trans pan to get at it.
Also, I'm assuming this is likely the reason it feels like the e-brake is on upon initially driving forward.
Old Sep 26, 2017 | 12:27 PM
Yep, pressure and temp sensors are one and the same.
Old Sep 26, 2017 | 12:29 PM
portlandv10
And the lack of power issue likely from this malady? - at least based on correlation based on diagnostic scan??
Old Sep 26, 2017 | 01:17 PM
If the trans is in limp mode, it would sure seem like the engine is down on power......
Old Nov 25, 2017 | 12:59 AM
Forthegrove's Avatar
Forthegrove
posted in wrong thread on accident.
Last edited by Forthegrove; Nov 25, 2017 at 01:10 AM. Reason: posted in wrong thread.
Old Nov 25, 2017 | 01:00 AM
Forthegrove
sorry posted in wrong thread on accident and don't know how to delete.
