Electrical HELP ASAP!!!!!!!
Old Oct 1, 2017 | 02:49 PM
  #21
dacker's Avatar
dacker
That's where it was laying up against the one that melted
Old Oct 1, 2017 | 03:10 PM
  #22
Need to fix that too.
Old Oct 1, 2017 | 04:51 PM
  #23
dacker's Avatar
dacker
I will and I see what your thinking it looks like but its really just melted plastic sitting on the wire lol.
Old Oct 1, 2017 | 07:29 PM
  #24
dacker's Avatar
dacker
Alright pulled the power center from under the hood and can't find the matching wire that's burned from that pin that I'm pointing to with the yellow arrow going into it... I did find this one burned but it's going to the ac blower relay and I'll fix it too. But can someone help me figure out what the pin I'm pointing to in the pictures runs to... I know it goes through the firewall but can't find it after that... The bundle goes 2 ways either the power distribution center or over to the ecm module but surely there is a diagram somewhere or Pin out somewhere of that plug so I can go directly to where it comes out to and check the wire at that end.
Old Oct 1, 2017 | 08:45 PM
  #25
Do you have a copy of the FSM yet? If not, get one here. Wiring diagrams, and connector pinouts are in section 8W.
Old Oct 1, 2017 | 09:14 PM
  #26
dacker's Avatar
dacker
I do have that and called myself looking but electrical schematics have never been my strong point but I'll peek at it again
Old Oct 1, 2017 | 09:32 PM
  #27
What plugs into the connector on the other side?
Old Oct 1, 2017 | 10:38 PM
  #28
dacker's Avatar
dacker
Here's a pic of the connector together then the bundle passes through the firewall and goes to the ecm or the distribution panel or fuse box thing under the hood.
Old Oct 2, 2017 | 08:29 AM
  #29
What plugs into it in the PDC?
Old Oct 2, 2017 | 08:09 PM
  #30
dacker's Avatar
dacker
Plug ID.pdfPlug ID.pdfPDC = Power Distribution Center? If so thats what I am saying I am having h hard time figuring out where it goes when it leaves the back of that plug and goes through the firewall. Thats why I was hoping someone could help me track the other end of it via knowing what pin it was. I am attaching a pdf that I put arrows on of the plug from the FSM and which pin it is... This however tells me nothing about what the wire is for or anything it just tell me the number the plug ID and the color....
