Electrical HELP ASAP!!!!!!!
Old Oct 15, 2017 | 07:45 PM
  #61
Doesn't that plug into the back of the cluster?
What was your fix??
Old Oct 15, 2017 | 08:09 PM
  #62
dacker's Avatar
dacker
Apparently the plugs going into the cluster weren't seated good enough. And no it just plugged into a cap about knee height behind that panel
Old Oct 15, 2017 | 08:13 PM
  #63
Well, at least its fixed.
Old Oct 15, 2017 | 08:32 PM
  #64
dacker's Avatar
dacker
You are correct!!! I really appreciate all your help my friend along with anyone else that contributed!!!
Old Nov 30, 2017 | 08:49 AM
  #65
dacker's Avatar
dacker
Default 90% Complete
Well I know it's been a couple weeks but I got most everything up and running. I even did the led conversion while I had everything apart. Last 2 issues I have to fix that I need a little advice on and I'm betting they're related to each other in some way.
1) with the lights off and I apply the brake the parking lights and instrument panel lights come on along with the brake lights.
2) the remote start/alarm functions exactly as it should with the exception of actually cranking. I hit the button, parking lights come on, I hear the fuel pump cycle, then nothing. After 5 or 10 seconds it repeats the whole process since it never actually cranked and does it for 3 cycles. So any advice on where to start looking for these last couple of issues?
Old Nov 30, 2017 | 09:10 AM
  #66
You have a short somewhere...... stepping on the ebrake shouldn't turn on ANY lights with the ignition off....... That's just bizarre.
Old Nov 30, 2017 | 12:23 PM
  #67
Maximillio's Avatar
Maximillio
I would assume short somewhere as well for brake lights issue. So check the brake light wire that runs under dash. In my truck it was a White with tan wire.
As far as remote start, it sounds like its not sending voltage to the starter to crank the engine, so I would check that, but if your truck is starting with the key, Id be under the suspicion the wire is fine and the remote start would be at fault for not sending out. The way remote starts work is they have a 12V constant power that they can supply to other wires. So essentially when it begins the remote start process, it powers the wires that turning the key to on in, so Ignition 1 - 2 and accessory power, if I remember right, I could check for you. And that is essentially the key turning forward, then at that point it applies power to the starter wire to begin cranking it, until it detects the engine has started. Once again just mimicking the key being on, then turning forward. If youre unsure about wires, always google online, there are generally wiring diagrams for the common remote start wires, and even then, I would do things like probe the wire and press the brake to ensure proper function. Starter wire in mine was yellow color, duno about your year.
As a quick reminder, if you're probing wires with a DMM, Don't stab yourself in the finger, and if soldering any live wire, don't create a short to ground with the iron lol
Old Dec 3, 2017 | 07:53 AM
  #68
dacker's Avatar
dacker
Well I figured out the brake/parking lights issue. I knew this bulb was out just never dreamed it would have caused that issue but changing it fixed it. Now just have to figure out the remote start issue. And trust me I've probed my finger more than once and that crap hurts!!!! Lol
