driveline noise
Old Sep 30, 2017 | 04:30 PM
oledad's Avatar
oledad
Default driveline noise
I have a 2001 Ram 1500 Laramie XLT 2 wheel drive, 5.2 L engine with 152,000 miles. I have developed a strange noise somewhere in the driveline. Put the rear on jackstands and I get the "squeaking" noise at low throttle in forward gears only. Makes absolutely no noise in reverse. I bought the truck brand new in 2001 and have put every mile on it. I do occasionally tow my car hauler behind it. Any ideas? Transmission? Pinion? Rear end? Does not seem to be u-joints in the driveshaft. Thanks, Steve Bennett
Old Sep 30, 2017 | 05:36 PM
U-joints would be my first guess, bad spots loaded in one direction, but, not in the other. If they are original, it wouldn't hurt to inspect them. Pull the driveshaft, see how they feel.
Old Sep 30, 2017 | 07:53 PM
oledad's Avatar
oledad
I'll pull the driveshaft tomorrow after church and replace front and rear. I replaced the front at 123,000 (2013) but the rear is the original. Thanks for the input. Steve
Old Sep 30, 2017 | 10:37 PM
Let us know what you find.
Old Oct 2, 2017 | 11:34 AM
oledad's Avatar
oledad
Pulled the driveshaft this morning and found the rear u-joint (original from 2001) had 2 dry sockets. Factory sealed so no way to lube. Replaced with a new MOOG u-joint with grease zerk. No driveline noise at all. Thanks for confirming my suspicions and saving me a costly bill at the dealership. Steve
Old Oct 2, 2017 | 01:23 PM
Gotta love the easy ones.
