Trans change?
Old Oct 25, 2017 | 09:59 PM
Adamvon's Avatar
Adamvon
Default Trans change?
I have a 99 with the 5.2 and the nv3500 5 speed trans that I have wrecked and I'm getting another truck that has the 5.9 v8 that I want to put that nv3500 in both trucks are 4x4 So the question is will the nv3500 for the 5.2 bolt up to the 5.9
Old Oct 25, 2017 | 10:12 PM
Yup. Bolt right in. Of course, the NV3500 never came stock behind the 5.9..... so, go easy on it.
What year is the 'new' truck?
Old Oct 25, 2017 | 10:18 PM
Adamvon's Avatar
Adamvon
[QUOTE=HeyYou;3363404]Yup. not sure a friend of mine has it and the rear doors open on it so it's atleast a 98
Old Oct 25, 2017 | 10:25 PM
Adamvon's Avatar
Adamvon
What's the difference between the nv3500 and the nv4500
Old Oct 25, 2017 | 10:43 PM
Adamvon's Avatar
Adamvon
The new truck is an 01
Old Oct 25, 2017 | 10:54 PM
Should be pretty much a direct swap then. You can use all the bits and parts from the 99, and they will bolt right into the 01. (pedals, wiring harness, and such) You will need to have the 01 PCM flashed with a manual trans tune though.... Can't use the 99 PCM...... It'll be annoyed in the newer truck. You *might* be able to just flash the VIN on the 99 PCM..... not sure.....
NV4500 is heavier duty, and won't explode quite so quickly behind the 5.9.
Old Oct 26, 2017 | 01:42 AM
frankie_b_jr's Avatar
frankie_b_jr
One thing I didn't see HeyYou mention was the flywheel. The 5.2 and 5.9 don't interchange because of engine balancing. You will need either a new flywheel for the 5.9, or have the 5.2 flywheel balanced for the 5.9. Some engine shops have a template just for this purpose.
Don't forget to get a new pilot bearing with the adapter bushing too. You'll see why when you look at the end of crankshafts.
Old Oct 26, 2017 | 11:10 AM
Adamvon's Avatar
Adamvon
Can I get the pilot bearing with the adapter bushing at autozone or oreileys
Old Oct 26, 2017 | 11:18 AM
frankie_b_jr
Yes you can. Here is the Napa page for it: https://www.napaonline.com/en/p/BRGFC69907. You should be able to give any auto parts store that number and get the right thing.
