2500 brake mod on 1500
Old Oct 26, 2017 | 01:26 PM
BigGreenRam's Avatar
BigGreenRam
Default 2500 brake mod on 1500
great mod should have done it sooner. The braided steel line replaced all the rubber lines stops like a new truck. So I had a new paint job to go with it still a work in progress
Old Oct 26, 2017 | 05:52 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What's the mod?
Old Oct 27, 2017 | 09:39 AM
Tboned's Avatar
Tboned
Looking good!
Old Oct 27, 2017 | 05:08 PM
BigGreenRam
Thanks and the mod is wheel cylinders and calipers from a 2500 dodge truck used on a 1500 search it
Old Nov 1, 2017 | 07:38 PM
Spillage's Avatar
Spillage
2500LD brakes on a 1500... it is a nice upgrade.
All bolt up parts, no mod's.
https://dodgeforum.com/forum/2nd-gen...ml#post3346235
Old Nov 10, 2017 | 08:39 AM
wca_tim's Avatar
wca_tim
I did this on my truck, works great! get the larger caliper 8800 gvwr calipers and use good 1500 series rotors.
btw. I was also going to do this on a 4x4 van I'm working on, but wound up picking up dana 60 8 lug axles complete with brakes and so have a spare set of (used but serviceable) calipers and freshly turned 5-lug rotors if anyone nearby needs a set for the upgrade... All you should need is new pads (I'm in Greenville, NC)
