Engine wants to stall and 46re pass from drive to neutral
Hello everyone, I'm from Belgium so sorry for my disastrous language. I own a 1999 5.9 ram for two years, the only problem is that it stalled when I slow down at each junction. since I replaced all the sensors of the vehicle. I clearly saw a clear improvement. But he still has a problem and only cold. When I start it and I stop at a crossroads the engine wants to stop and the transmission goes into neutral, and when I accceles the engine goes up in RPM while remaining neutral, then the forward is recovering , a shock when mating occurs and I can continue to drive. when it happens I have already tried to manually switch to neutral and then go back to drive but nothing happens. I also replaced the converter.
If anyone has an idea it would arrange me
thanks
thanks
Your english isn't too bad. Better than some of the native speakers I have had to deal with.
You have a couple different problems there. For the stalling, I would recommend pulling the throttle body, and giving it a REALLY good cleaning. (leave the battery disconnected while you clean it.) If you have an aftermarket IAC valve, replace it with a genuine dodge part.
For the trans, doing a fluid/filter change, and a band adjustment.... would be a good starting point. Don't skip the band adjustment.
Trending Topics
