2001 5.9 360 issues
Old Nov 24, 2017 | 08:21 PM
Jmikk's Avatar
Jmikk
Default 2001 5.9 360 issues
Hey everyone, I’m picking up a 2001 ram 1500 on 2500 axles and suspension 5.9 360. It won’t idle, runs perfect with your foot holding it at 1k. I know the idle control valve can jam and truck won’t get air but it moves so that’s out of the question. Could it be battery and alternator? The alternator squeals and might be siezing up and the battery went dead after a light was left on, what do y’all think?
Old Nov 24, 2017 | 08:25 PM
The bore the IAC valve goes in tends to be a nice place for crap to build up, so, the IAC actually closes off the passage a LOT sooner than the PCM expects.... so, bad idle. Also, aftermarket IAC valves tend not to react as quickly as the stock mopar piece, and are a major contributor to unstable/inability to idle. Low fuel pressure can do it to....... or any of a number of other things.
Welcome to DF!
Old Nov 24, 2017 | 08:49 PM
Jmikk's Avatar
Jmikk
Welcome to DF!
interesting, I’ll replace it anyway! Thanks for the welcome!
Old Nov 24, 2017 | 10:57 PM
Clean it good when you replace it, and get the new one from the dealer. (or, wherever you can get a genuine OEM part.) Let us know how it goes. Be sure to leave the battery disconnected while you are in there. (resets the PCM.)
Old Nov 24, 2017 | 11:29 PM
Jmikk's Avatar
Jmikk
i will definitely let you know, I’ll be back here my other issues and questions as well, the quick response was fantastic!
