Truck shakes at 60 mph
Sorry also new stabilizer rods and tie rods ,inner and outer , new gear box and I think that’s it .. Truckhas 280,000 miles on it when I got it and I’m finding all original parts everywhere .. but I got it for next to nothing .its just that everything is fine u til like precicely 55-60 and starts to shutter feels like it’s behind me almost , hard to really tell . I just know that if I get it up to 70 mob it’s done ... until I slow down back to 60 and starts a Suttle shutter but it’s really annoying and noticeable.. can’t tell if it’s worse or better since all the work has been done (actually think it’s the same )
thanks again .
thanks again .
Could be brakes, wheels, or trans?
I chased a vibe for over a year and finally found it in the tires. But does yours actually go away at 70 or just gets so fast you can't feel it?
Another vibe I had years ago was after getting new tires, the old ujoint in driveshaft didn't like it. New ujoint= vibe gone.
Trending Topics
It actually goes away as soon I get past 60mph and is smooth sailing ... I’ll check the tires and swap them around like you said and I’ll get back to you on the result ... I did notice when I had the truck jacked up :i spun the wheels by hand and noticed that the passenger side wheel spins but I can hear the brake kinda rubbing on it and it doesn’t spin very long (maybe one complete rotation ) and the drivers side with the same amount of force exerted spins about 2 -3 complete revelations before coming to a stop while not hearing anything on the brake pad .. I’m not sure how to adjust this . Can you point me in the right direction . Oh and the rotors are new (both sides )
thanks for all your input .. I appreciate everything
The issue you described with the wheel drag sounds like a possible dragging/sticking brake caliper. Check to see that the caliper mount/pivot points are properly greased with high temp brake grease and aren't seizing/sticking. If they are, this can cause the rotor to overheat and cause a vibration, especially when braking.
