Dosen't Rev after 4,500 rpm. After running a while it revs below 3000 rpm & stutters
Old Dec 2, 2017 | 01:41 PM
  #21
Ok, looked at the wiring diagrams..... O2 heater circuits go thru the ASD relay, which, if the engine runs, is working properly....... (sorry 'bout that....)
Check Fuse "K"..... that's the heater circuit for the O2's.
Old Dec 2, 2017 | 01:44 PM
  #22
kevingnaniah's Avatar
kevingnaniah
Can you explain what or where fuse K is. Thank you
Old Dec 2, 2017 | 01:47 PM
  #23
In PDC, in the group of fuses toward the front, and outside of the truck. It's the one closest to the fender. (should be a diagram on the underside of the cover for the PDC.)
Old Dec 2, 2017 | 02:00 PM
  #24
kevingnaniah
Yes that’s where I saw the o2 heater relay. Right next to the battery right? The diagram shows the relay for both front and rear o2 heater. But the places shown for heater relay is empty
Old Dec 2, 2017 | 02:03 PM
  #25
Yeah, evidently they changed their minds about where to get power from, and didn't change the design of the PDC.
Old Dec 2, 2017 | 02:04 PM
  #26
kevingnaniah
What could I do from here
Old Dec 2, 2017 | 02:08 PM
  #27
You still have the codes.... so, time to start testing at the O2 sensor connectors. With the engine running, should see 12 volts (or, battery voltage...) on the Dark Green/White wire, 5 volts on tan/white wire for the front O2, and on the orange/black wire for the rear.
Old Dec 2, 2017 | 02:20 PM
  #28
kevingnaniah
Should I check the rear o2 (downstream) because the front upstream fluctuates and the downstream stays at 1
Old Dec 2, 2017 | 02:24 PM
  #29
Yeah, start there, see what ya get.
I don't recall, have you replaced the sensors??
Old Dec 2, 2017 | 02:27 PM
  #30
kevingnaniah
I replaced both the sensors before, not after my drive to the gas station and the code p0141
