i installed new hid headlights but dont have low beams
Old 12-26-2017, 02:24 PM
AgentACDC's Avatar
AgentACDC
AgentACDC is offline
Default i installed new hid headlights but dont have low beams
i just replaced my factory headlights with new aftermarket H.I.D. headlights but now when i turn on my headlights to the low beam setting the yellow running lights come on but not my headlights. my high beams come on and my fog lights but not my low beams. 2000 ram 1500
Old 12-26-2017, 05:20 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,214 Likes on 2,965 Posts
You want to be in the second gen section.
Do you have housings designed for HID headlights? Is yours a Sport model truck?
Old 12-26-2017, 07:52 PM
AgentACDC's Avatar
AgentACDC
[QUOTE=HeyYou;3371995]You want to be in the second gen section.
No its not a sport model, and it came with the same plug that came factory for my trucks headlights, plugged right in, same for the box to run the HID it turns on but only on high beams, it worked fine before with the old lights
Old 12-26-2017, 08:04 PM
HeyYou is offline
Putting HID bulbs in enclosures that weren't designed for them isn't a good idea. You will blind oncoming drivers.
As to why they don't work.... that's a good question.... Maybe have a wire in the wrong spot? Or is it supposed to be plug and play?
Old 12-26-2017, 08:09 PM
brian102's Avatar
brian102
brian102 is offline
the style you describe has 2 settings... off and blind everyone.
Old 12-26-2017, 10:30 PM
AgentACDC's Avatar
AgentACDC
the set of headlights i bought came with a hid bulb already in the slot all i had to do was plug my wiring harness into it. it has 4 accent leds for looks that i have yet to wire up but besides that to the best of my knowledge everything is connected properly. gonna check it tomorrow. heres the headlights https://www.protuninglab.com/xehi94r...d=140845616938
Old 12-26-2017, 10:31 PM
AgentACDC's Avatar
AgentACDC
its low beam is supposed to be 10,000k blue and high im not sure speks but it shouldnt only be working on high so im totally lost
Old 12-27-2017, 08:31 AM
jkeaton is offline
Put the stock bulbs back in. 10,000 k is just dumb and will get you pulled over by the police.
Old 12-27-2017, 04:39 PM
HeyYou is offline
Pre-Installed HID low beam included.
This little tidbit has me wondering...... are you actually getting low beam headlights, and there simply ISN'T a high beam??? It doesn't talk about high beam at all....
Old 12-27-2017, 07:27 PM
AgentACDC's Avatar
AgentACDC
Wow..... I never even thought about that. That is very interesting, thank you for seeing that little bit of information. It could be just solely a low beam headlight without a high beam function, and if that is the case then i have a fully functioning headlight that i thought was broken somewhere
Quick Reply: i installed new hid headlights but dont have low beams
