ram 5.9 stalling issue
#31
I got a few new things to add to think that the last seller replaced the PCM without flashing, borrowed a friends abs reader and found these codes..
63 shuttled reset switch concern
66 power relay short
84 mismatched VIN
37 rear sensor signal erratic
35 rear sensor circuit malfunction
78 base brake system incident
84 mismatched VIN
#32
got a new pcm through flagship one that was flashed to my vin, still same issues as of late, rough idle that putters out. I can go back to shotgunning sensors I haven’t replaced yet like iac(honestly don’t remember because I went though so many). Sorry for the long *** drawn out post but I’ll check into anything y’all suggest
#33
#34
#36
What brand sensors? How is the fuel pressure? By "putters out" I assume you mean slowly die, if that is the case, I would hook up a fuel gauge and watch it while the truck is idling
#37
mostly duralast sensors as that’s what is readily available, I did go mopar for the crank position sensor though. I rented a fuel tester but as I was trying to use it earlier I couldn’t get the truck to run at all really, I’ll try again tmrw and see if I can get any data
#38
