1997 Dodge Ram 1500 4wheel drive front end sqeaking when it is put in 4 wheel drive
Old Jan 29, 2018 | 01:40 PM
Frank66impala's Avatar
Frank66impala
Default 1997 Dodge Ram 1500 4wheel drive front end sqeaking when it is put in 4 wheel drive
Hi
I have a 1997 Dodge Ram 1500 4 wheel drive that the front end is squeaking while driving when you engage the 4 wheel drive. I have changed the front hubs and brakes and rotors. What could also be causing this??
thank you
Old Jan 29, 2018 | 02:40 PM
U-joints in the outer axles, or front driveshaft.
Welcome to DF!
Old Jan 29, 2018 | 06:12 PM
Frank66impala
ok, how can I tell which one is bad or would it be best to change them all out, I am pretty sure they are all original
thank you
Old Jan 30, 2018 | 10:19 AM
Have a look at 'em. Turn the steering to one side or the other, then try and rotate the tires. See if there is any binding. Generally, if they are bad, it's pretty obvious, but, that is not always the case.
Old Jan 30, 2018 | 09:52 PM
2bit's Avatar
2bit
I like Spicer 5-3226X u-joint for the axle shafts. They have the needle grease fitting in the end of a cap. The ones with the fitting in the cross are terrible to get at once installed in the truck.
