HELP: What is this cable/wire from the starter called...
HELP: What is this cable/wire from the starter called, and where can I buy one. Can't seem to find it anywhere and the one I have is done for.. Plz help
Its not a "normal" cable, the other end pigtails to off to connect to the positive battery terminal and then off to a harness under the power distribution fuse box..
Hhhhmmmm..... My 96 didn't look like that...... But, it's not like dodge never changed anything.....
You may have to custom make one.... could try the parts store... I doubt they would have it in stock, but, they might at least be able to show you a picture.
Weird.. LOl, I mean I just got a new battery, is that something you can put on the battery or? Yours looks so much different then mine. I've got this harness that goes under the power distribution fuse box.. the wire from the starter goes directly to this harness and plugs in under the power distribution fuse box- i guess thats the part I'm struggling with. Harness from starter to under power distr. fuse box.
Yes, the grey-ish wiring harness pictured has one wire (the black) going to the small terminal on the starter motor under the truck, and the other one from the harness pictured goes to the positive terminal on the battery. The grey-ish wiring harness plugs into a female piece under the power distr. box in picture #3, labeled "What is this?"- I'm not sure of its name, but I believe its been referred to as the "ignition to starter harness" or something like that.
