Ball joints installed wrong ???????
Old Apr 9, 2018 | 10:19 PM
Packer2997's Avatar
Packer2997
Default Ball joints installed wrong ???????
Hey ram fam so I just bought a 95-96 dodge Dana 60 axle and when looking at other axles of different years it appears that my ball joints are not pressed into the c-knuckle on the axle tube but on the caster arm I think that's what you call it am I just over reacting or are the ball joints actually put in wrong never dealt with this before.
Old Apr 10, 2018 | 08:29 AM
Could you post a pic?
Old Apr 10, 2018 | 12:53 PM
Packer2997's Avatar
Packer2997
There you go
Old Apr 10, 2018 | 01:02 PM
OK, that's correct. Weight of the vehicle will keep the joints pushed into the C on the axle.
Old Apr 10, 2018 | 01:32 PM
Holy rust batman.....
Old Apr 10, 2018 | 01:41 PM
AtomicDog's Avatar
AtomicDog
That type of rust is not uncommon to see with our friends in the Northeast and Midwestern areas. Down south in Winston-Salem, NC, not so much.
Old Apr 10, 2018 | 02:25 PM
Packer2997's Avatar
Packer2997
Alright perfect I've just never seen it setup the way before
Old Apr 10, 2018 | 06:27 PM
Ramman18's Avatar
Ramman18
Weird. It's upside down compared to the Dana 44 and other D60s. How're you supposed to grease it? When did they change it? Looks very, very odd.
Old Apr 10, 2018 | 10:12 PM
AtomicDog's Avatar
AtomicDog
That's the way my '96 front Dana 60 ball joints are oriented. To grease them, I installed the grease fittings, greased the joints, then removed the grease fittings and installed threaded plugs, as the grease fittings protruded just enough to interfere with the u-joint/stub axle assembly.
It also has a weird setup where the front rotor and hub on each side are held together with knurled lug studs
Old Apr 10, 2018 | 11:30 PM
Ramman18's Avatar
Ramman18
Yeah, some pics online show the normal ball on top so I wonder when Dodge/Dana changed the design. Had to be mid-90s I'm thinking. I see pics of both styles.
