injector P0201 & P0208 issue
Old Apr 10, 2018 | 04:46 PM
Lee Darby's Avatar
Lee Darby
Default injector P0201 & P0208 issue
2001 Dodge Ram 2500 5.9L Gas Vin:Z runs roughtchanged injector 1 & 8 and camshalf sensor, still same issue ran test checked wiring, even tried different PCM same codes. Im Lost now not sure what else to do
Old Apr 10, 2018 | 05:54 PM
Check the wiring for those two injectors. Noid light makes it easy. Get one at your local parts store. See if the injectors are getting pulse signal.
Old Apr 10, 2018 | 06:03 PM
Lee Darby's Avatar
Lee Darby
Yes I checked and also used a Noir Light, I'll start the truck code p0201, clear codes and I'll check codes again p0208, I'll clear them again recheck codes and p0201 I ran pcm test replaced ground to pcm still same issues tested relays all checked out, tested fuel pressure 47psi
