Dana 60 help
Old 04-19-2018, 02:11 PM
Packer2997's Avatar
Packer2997
Packer2997 is offline
Default Dana 60 help
Hey guys just wondering where I could get two of these spacers its on the back side of the hub both of them are gone like that should I just go to a junkyard and try to find them or?
Old 04-19-2018, 02:19 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Try the local transmission repair shop. Any place that works on transmissions, axles or 4x4s should have one on hand or get one for you. Thats a pretty common item.
Old 04-19-2018, 04:01 PM
NCC74656's Avatar
NCC74656
NCC74656 is offline
i made my own, i had some thin sheet metal lying around and used a dremmel while holding it over the axle to router out the pattern
Old 04-19-2018, 04:05 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Sure that isn't a brake dust shield?
Old 04-19-2018, 05:04 PM
Packer2997's Avatar
Packer2997
Positive it has that spacer between the hub and knuckle then it has the dust shield too
Old 04-19-2018, 05:05 PM
Packer2997's Avatar
Packer2997
Do you know if it has any special bad I've been searching for them for a minute
Old 04-19-2018, 07:49 PM
racefan41's Avatar
racefan41
racefan41 is offline
backing plate spacers or gasket? i'm seeing something similar for other rear ends, but nothing that shows for dana 60
Old 04-20-2018, 08:43 AM
MoparFanatic21
My mistake wrote that before bed. Unfortunately finding parts will be rough as one company will call it "X" whole another company calls it "XY"
Old 04-20-2018, 10:53 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I just looked through the 1994 thru 1996 Dodge truck factory parts catalog and didn't see it listed as a part. What year Dana 60 are you dealing with? Might want to check the Dodge truck parts catalog for the year Dana 60 you are dealing with to obtain a part number and description for this part.
Old 04-20-2018, 01:54 PM
Packer2997's Avatar
Packer2997
When i looked up the bom number it's saying it's .95-96
Quick Reply: Dana 60 help
