Thanks for the pics and the suggestion to drill and tap the plenum for the second engine coolant sensor 2Bit. Only took a little over an hour to it. Truck is running better. Im going to take it to the dealer to have the pcm flashed and the fuel sync set correctly. I will have them diagnose it if that doesnt solve the problem. I cant thank everyone enough for all the info and advise you guys have given me.
