97 ram code 43
Old Apr 30, 2018 | 03:02 PM
soloflite's Avatar
soloflite
Default 97 ram code 43
Hi, been chasing a code 43, more specifically, P0306-Powertrain cylinder 6 misfire detected and P0300 - Powertrain random/multiple cylinder misfire detected.
I pull all the plugs yesterday and installed autolite 3924's copper. It had the platinum autolites and all looked clean. Truck seemed the same after install, no real difference. I do notice hesitation at idle, and have smelled fuel after start up on occasion since the check engine light came on. I'm also using 8mm wires which all look good. truck seems to drive fine, good pickup w/o hesitation.
Wondering what else to test, ie. fuel pressure will be a PITA, it's a plastic fuel rail w/ no test port, I do have an after market I can put in line to test. Also wondering if this could be the ignition coil?? I replaced the cap/hep/and rotor about 3k miles ago.
thoughts?
thanks...
Old Apr 30, 2018 | 03:16 PM
Clear the codes, and see if they come back.
How old is the distributor cap an rotor??
Old Apr 30, 2018 | 03:40 PM
soloflite's Avatar
soloflite
I've cleared it 3 times so far, keeps coming back. cap and rotor less than 3k..
Old May 1, 2018 | 07:49 AM
Check compression.
Old May 2, 2018 | 01:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I thought there was a test port on the fuel rails
Old May 3, 2018 | 07:55 AM
frankie_b_jr's Avatar
frankie_b_jr
97s have a wonky plastic fuel rail that doesn't have a test port. It's a poor design that was thankfully only used for that year.
Old May 3, 2018 | 10:27 AM
true blue's Avatar
true blue
The crank sensor does double duty here I believe. It also records misfires, AND as a bonus, it can cause misfires (or so I hear) if it's a replacement sensor and not mopar in origin. Also possible it's bad gas. Let her run thru the tank n fill her back up again.
Old May 3, 2018 | 06:07 PM
soloflite's Avatar
soloflite
thanks, also changed crank sensor not too long ago, also was a mopar one. will have to check fuel pressure some how and compression.
