Stressed.
Old May 12, 2018 | 07:49 PM
PITTND4L47's Avatar
PITTND4L47
Default Stressed.
New here, and I've done more work on my truck, the wifes KIA,and sons Chevy Trail Blazer than any other vehicle in my life. And go figure, my truck is still out for the count. Changed plugs&wires,new distributor cap,new alternator, and today a new Downstream o2 sensor. Same problem still happens get up some speed with foot on gas pedal it hesitates, like its fighting for gas. Thing is it was doing the same thing before I changed one thing. I'm lost, can anyone give some advice. Thanks.
Old May 12, 2018 | 08:53 PM
Dodgevity's Avatar
Dodgevity
What engine? Have you checked fuel pressure? Any codes?
Old May 12, 2018 | 09:13 PM
PITTND4L47's Avatar
PITTND4L47
5.9 V8 2500, and nonhavent checked pressure, and no check on codes. Kinda nervous to drive it.p
Old May 12, 2018 | 09:14 PM
PITTND4L47's Avatar
PITTND4L47
Old May 12, 2018 | 10:10 PM
Ramman18's Avatar
Ramman18
The downstream O2 doesn't have any effect on driveability, just the front one.
We need way more info to help diagnose. We aren't therapists.
Old May 12, 2018 | 10:20 PM
true blue's Avatar
true blue
Get ur hands on a scanner that'll read live data, THE ABSOLUTE BEST FRIEND YOU CAN HAVE N WISEST MONEY YOU CAN SPEND AT THIS POINT.. Record data at idle,1500 n 2500 RPM. Ur looking for fuel trims/long n short,coolant temp readings, Last but not least, O2 readings...upstream should move up n down, the downstream should ideally be steady. All of these readings should be done at normal operating temps n in ur driveway. Easier to do that way.
Old May 13, 2018 | 10:53 AM
Moparite's Avatar
Moparite
5.9 V8 2500
WHAT YEAR???
We don't have one of these either...
Old May 13, 2018 | 12:39 PM
Check for any codes, and also check fuel pressure.
Old May 13, 2018 | 01:17 PM
PITTND4L47's Avatar
PITTND4L47
98 Dodge Ram 2500 V8 5.9 Gas.
Old May 13, 2018 | 01:18 PM
PITTND4L47's Avatar
PITTND4L47
Thanks for the help, I'll let you know what I find out.
