Help with Overdrive
Old May 15, 2018 | 05:19 PM
JusMedic's Avatar
JusMedic
Pretty much.
You can pick up a complete set off of ebay, that includes the BW heavy duty solenoid, sensor, tcc and O/D solenoids, with the added bonus of an output speed sensor for around 200 bucks.
this is would be for ‘01 46re and not 98 correct? Aside from being new with more piece of mind, is there any benifit over savaging the parts from original trans?
Old May 15, 2018 | 05:56 PM
Correct.
You replaced the original trans for a reason, no? Why would you put parts from a blown up trans, into a good one? Nah. Replace the electronics. You get better parts, that are supposedly more reliable.
Old May 16, 2018 | 08:00 AM
JusMedic's Avatar
JusMedic
Correct.
the connectors will need to be spliced and switch for 98 to 01. Is it work just swapping the whole value body?
Old May 16, 2018 | 02:37 PM
Just swap the electronics. No need to swap the valve body, or cut/splice anything.
Old May 16, 2018 | 02:46 PM
JusMedic's Avatar
JusMedic
okay I thought u mentioned the internal plug for sensors and switches had different plugs Been so busy with house stuff I haven’t had a chance to dig into either trans
Old May 16, 2018 | 05:27 PM
There is an internal plug in the trans where the solenoids, and governor stuff meets up. That connector may have changed as well. Check and see.
Old May 24, 2018 | 01:17 PM
JusMedic's Avatar
JusMedic
I think that might have done it. Only been able to drive it up to 45-50 but I can feel it shifting into OD and the OD button actual shifts it in and out and changes rpm. I will be on highway later today. Thanks so much Today is going be a good day 👍🏼🇺🇸
Old May 24, 2018 | 05:23 PM
JusMedic's Avatar
JusMedic
Okay, so took it on the highway and it still doesn’t seem to be shifting into OD however it’s not staying locked in 3rd because when I let off the throttle at 65-70-75mph the rpms drop from 2600-3000rpm down to 1100 and then I hit the throttle and it doesn’t catch at all not until rpms are are back around 2600 and it will start pulling Also now have a p1740 code and the OD button changes rpm but only by a few hundred depending if it’s in or off Stumped again Ugh
Old May 24, 2018 | 06:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The OD unit (on the back of trans before transfer case) is know for a smap ring to break and cause no OD and eventually runr your tranny. Might want to check that.
Old May 24, 2018 | 06:35 PM
JusMedic's Avatar
JusMedic
That’s what prompted the first trans to shot the bed I lost reverse also and pull three pieces of the snap ring out still some pieces floating in that trans some where
