Transfer case vibration
Old May 28, 2018 | 07:22 PM
Jeff Stone's Avatar
Jeff Stone
Default Transfer case vibration
hopefully a little help will come from this. At or near 65 my transfer shifter starts to shake, I can hold it and feel a strong but not exploding vibration. I removed front drive shaft, installed new spicer u joints in rear shaft. Can’t feel anything loose checked pinion bearings, tail of transfer , output to front axle at transfer. Nothing. Thoughts?
Old May 28, 2018 | 07:28 PM
Trans mount?
Old May 28, 2018 | 10:06 PM
2bit's Avatar
2bit
Did you check the snap ring on the output shaft? The tail housing has to be removed. You might need a Transfer case Saver.
http://www.drivetrain.com/parts_cata...ase_saver.html
Old Jan 4, 2024 | 03:11 PM
earl28529's Avatar
earl28529
Don’t know if you have checked the mounting studs or the overdrive housing. I just pulled my transmission for a bad vibration and it was a broken overdrive housing where the t-case bolts up.
Old Jan 4, 2024 | 03:12 PM
I can see how that might cause some problems......
Old Jan 4, 2024 | 03:13 PM
Granted, this thread is more than five years old...... I hope he has it fixed by now.
