Extended Cranking, Gas Smell in Oil
Hi everyone,
on my 97 5.9 Magnum Ram 2500 I almost always have extended cranking to start. Once it starts it may be rough for a second but then idles and runs strong. Have not noticed any loss of power. If I restart within a minute or two after shutdown sometimes it starts instantly. Every other time there is extended cranking.
I dont have a Schrader valve on the fuel rail so I need to get a tee to test fuel pressure but that is on the list.
Also the fuel mileage is at best 11mpg. 10 or under isn't unusual. It does have a pretty big lift (by PO), I'm guessing about 6 inches and 285s. Is this normal fuel range for this truck? It doesnt seem to matter if its city or highway, mileage is same.
I'm guessing I have at least one leaky injector. Any way I can test for this?
Thanks,
Ryan
Thanks,
Ryan
Trending Topics
I was having extended cranking with rough idle for a few seconds after start up, after the first start it would start instantly, unless it sat for a while, turned out to be the check valve in the fuel pump
was bad, allowing fuel to drain back to the tank.
Just something for you to consider.
