Brake Problems.... Again
Old Jun 26, 2018 | 08:04 AM
2bit's Avatar
2bit
On a Ford forum, the ABS had air trapped in it. There was a way to trip it with a scanner while bleeding the brakes. Guys that didn't have a scanner with that function would find a loose surface where they could get the ABS to apply, then go home and bleed the brakes.
Old Jun 26, 2018 | 08:37 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That's interesting. I think I figured out why my red BRAKE light is on. Ok give that a shot though to, wouldn't hurt anyhow.
Old Jun 26, 2018 | 09:10 AM
2bit's Avatar
2bit
It might take more than once. I trying to remember from a few years ago.
Old Jun 27, 2018 | 03:38 PM
MoparFanatic21
ABS light is off but was on when I started the truck. The brake light is one but it's probably because I can't bled driver's rear because the bleeder is stuck. I tried heat, chemicals, and vide grips and I know if I try anymore it's going to snap lol
Old Jun 27, 2018 | 05:09 PM
Replace the wheel cylinder.......
Old Jun 27, 2018 | 08:50 PM
MoparFanatic21
Eventually am going to but have a short trip so I'll do it when I get back. Closest parts store wants $48 for the 1 ton cylinders
Old Jun 27, 2018 | 09:12 PM
How do the lines look on the rear axle? Are they going to come apart willingly? Or are you going to have to replace those as well?
Old Jun 27, 2018 | 09:39 PM
2bit's Avatar
2bit
Wagner WC79767 1 1/16\" cylinder for $5.35 on Rock Auto
Old Jun 27, 2018 | 09:41 PM
MoparFanatic21
​​​​​​ I'll check on the shipping sometimes it's more expensive.
Old Jul 6, 2018 | 01:32 PM
MoparFanatic21
Ok here is what I did:
New front 7500lbs calipers
New 1 ton Dodge rear wheel cylinders
New rear hardware
Rests adjusted
Bled all four wheels
Bled proportioning valve with the bleeder on it
Checked all lines no leaks
​​​​​​Brake light still on brakes still feel soft when truck is running. Pedal is firm when it's off. I think I'm also getting brake fade to because when I press the pedal to do a hard stop the brakes don't grip harder.
