Rust prevention coatings
Old Aug 4, 2018 | 10:34 PM
  #31
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 2bit
I know that isn't a Dodge but it is a good test for a rust coating which is the topic of this thread. And I can't buy stuff for the Oxidizer Special if the work truck isn't working. I still want to read about other coatings. I may try the Eastwood ceramic next.
Just did the EastWood not worth the money in my opinion
Old Aug 5, 2018 | 07:18 AM
  #32
2bit's Avatar
2bit
Originally Posted by fj5gtx
Fancy spray gun, when those came out I almost bought one!
I usually put tarps under what I'm blasting so I can recycle the black beauty (media), and in general keep the place a little clean.
That's a great idea. Sand was all I could get in the time frame I had.
Old Aug 5, 2018 | 07:29 AM
  #33
2bit's Avatar
2bit
https://www.eastwood.com/eastwood-2k...lack-kits.html
Was it this product, the Extreme Chassis Black, or the Original Chassis Black?
Old Aug 5, 2018 | 08:45 AM
  #34
Spillage's Avatar
Spillage
Thanks for the tip. I've always thought about buying a needle scaler, but didn't know if they worked good.
Needle scalers do a good job... but boy, are they ever noisy.
Old Aug 5, 2018 | 08:54 AM
  #35
racefan41's Avatar
racefan41
That's a hell of a setup you got going on there. The finish looks good.
Old Aug 5, 2018 | 10:06 AM
  #36
Moparite's Avatar
Moparite
Well it depends on what condition the metal is in beforehand. If you are covering the rust or blasting it all off to bare metal. I didn't see any primer going on that bare metal. I would have used a good epoxy primer first before any coating. Epoxy primer is the best thing to use on bare metal. Covering rust vs converting it is another story. If it where mine and blasting it is out of the question then i would try a rust converter. Witch is best for your application is up for debate.
https://www.theruststore.com/Rust-Co...-FAQs-W48.aspx
A product i used but it was only a small area and it was cleaned up first with a wire wheel.
https://www.3m.com/3M/en_US/company-...3083284&rt=rud
Old Aug 5, 2018 | 11:35 AM
  #37
MoparFanatic21
Yes it was. I did the prep and everything like EastWood wanted. Still didn't adhere to the metal. Not only that but faded and is now flaking off
Old Aug 6, 2018 | 12:13 PM
  #38
2bit's Avatar
2bit
Thank you, it was a lot of hard work.
Old Aug 6, 2018 | 12:38 PM
  #39
MoparFanatic21
It pays off though :b
