Help Please
Old Dec 14, 2005 | 01:24 PM
  #31
steve05ram360's Avatar
steve05ram360
Default RE: Help Please
Pump, can you post a pic of the gasket? your current method sounds like a better option than the mopar one with rtv... I could be convinced to switch if I can see what it looks like... (looking to fix the truck this weekend)
Old Dec 14, 2005 | 02:01 PM
  #32
Pump's Avatar
Pump
ok let me see if my camera will cooperate and take some clear images of the gasket. I will post what I can asap..
Old Dec 14, 2005 | 02:04 PM
  #33
steve05ram360
cool thanks... also where and how much was the gasket?
Old Dec 14, 2005 | 02:18 PM
  #34
MAGICDSSMAN's Avatar
MAGICDSSMAN
The felpro gasket is what I used a few months back when I did my plenum. If I remember right it cost me less than $20. I have checked my plenum about once a moth since the change and have yet to see any oil so it looks to be holding up rpetty well.
Old Dec 14, 2005 | 02:48 PM
  #35
steve05ram360
the mopar one lasted about 6~8 weeks. and from what I can tell, failed all of a sudden (started leaking) started pinging so bad I had to pull over and yank the IAT plug to richen it up. (that works btw)
Old Dec 14, 2005 | 03:07 PM
  #36
Pump's Avatar
Pump
It costs $16 for the upper manifold gaskets and the plenum pan gasket in a set at autozone. I hope these pics came out good enough...I tried to compare it next to the mopar metal gasket so you could see the difference in a couple of pics. I think the fel pro is thick enough to seal off imperfections on the surfaces. I will let you know how it goes. Let me know if you need anything else.
Fel-Pro Gasket from Autozone
Mopar gasket
Fel-Pro
Gaskets side by side
Old Dec 14, 2005 | 04:49 PM
  #37
steve05ram360
Awesome, thanks... I'm thinking i'm gonna go with the felpro and return the mopar one. the felpro kit included the upper manifold gaskets as well? sounds like a much better deal than the Napa kit. the gasket they included was paper.
