5.2L to 5.9L engine swap
Old 07-28-2018 | 12:27 AM
Humenik360's Avatar
Humenik360
Default 5.2L to 5.9L engine swap
I have a 2000 ram 1500 2wd 5 speed 5.2. recently the motor blew up and I wanted to throw a 59 in there instead of the 52. Do I need a 5.9 l 2wd 5 speed computer or should mine work? Need the swap done in about 11 days so any info will help
Old 07-28-2018 | 01:31 AM
Ramman18's Avatar
Ramman18
Supposedly you need the computer to match the engine but not according to the Fastman. But you would have to look for a 2500 5.9 stick as the 5.9 was never paired with a manual in the 1500s. You might be able to even get the dealership to flash it.
Old 07-28-2018 | 01:40 AM
MoparFanatic21's Avatar
MoparFanatic21
The NV3500 should work as people over at pavementsucks are running then behind the 360 and it's holding up fine. Eventually though I would try to find it or buy new the NV4500. I saw them online brand new for $1800
Old 07-28-2018 | 09:23 AM
The 5.2 pcm will run the engine, but, will tend to run lean in open loop. (when cold, or, at large throttle openings.) You should be able to get the PCM flashed for the larger engine without too much trouble. Worst case, buy a tuner from Hemifever, or Flyin' Ryan for the larger motor, and manual trans.
Old 07-28-2018 | 09:38 PM
Humenik360's Avatar
Humenik360
tjanks for all the help. ive talked with more people about it and the pcm will work but like heyyou said it will need flashed.
Old 01-11-2019 | 02:56 PM
cman9898's Avatar
cman9898
ive got a 99 360 to replace a 97 318 becides the PCM and the flywheel is there anything else I need to replace/change? its got an automatic trans
