Ground strap information.
Old Aug 22, 2018 | 05:18 PM
Recarpenter's Avatar
Recarpenter
Default Ground strap information.
Hello from coarsegold ca.
My name is Richard and I need help with my '94 Dodge Ram 2500 that keep blowing the engine control fuse.
I have a 1994 Dodge ram V10 that keeps blowing fuse. The ground strap on the left side of the Cowell is broken. I would like to know where it stretches to.
It has to be somewhere near the brake master cylinder. Any help would be appreciated.
Richard.
Old Aug 22, 2018 | 06:32 PM
Welcome to DF!. That ground strap likely goes from the firewall, to the back of the head. (good luck seeing that..... the V-10 is really shoe-horned in there......) Probably not causing your fuse problem though. Which specific fuse is it? (number?)
Moving this to second gen ram for ya.
Old Aug 22, 2018 | 07:37 PM
Recarpenter
It's the 30 amp engine control fuse located in the fuse bank in the engine compartment .
Old Aug 22, 2018 | 07:50 PM
Download the service manual for your truck from here. Wiring diagrams are in section 8w. LOTS of stuff gets powered off that....... one of them has a short to ground.
Old Aug 23, 2018 | 10:50 PM
Torxhead's Avatar
Torxhead
Good places for ground connections are from the battery negative to as close as the starter as you can get. The starter uses the most from the battery and a #4 copper wire would work. The heads are another good location to help get a better spark and again run the wires direct to the battery. Steel is a very poor conductor of electricity. Other places that could use a good ground would be the alternator, headlights, and computer housing. When you use screws as tie in points on the firewall, the star type washer can dig in and help use that firewall as a grounding point since there are many points on the dash that use it.
