Tranny swap
Ian in wiggins Colo I have it out on the ground when I get home here later I'll post a set of pics of both t case and tranny I'll set it up to show how close it becomes to making me happy I thought my resent divorce was disappointing but this has taken the cake
Ooops. Too far. If you were relatively close, I would come for a visit. But, you ain't even remotely "close".
Pics would be good. Make sure you have good light. I wanna see pics of both, where they go together, and also depth of the input hub where the trans shaft goes into.
I suspect its just a matter of getting the splines to line up properly. With the trans in park, try turning the output shaft of the t-case a bit while pushing it forward. See if anything changes.
