New heads - Clearwater/Odessa Standard or Engine Quest heads?
Old Oct 24, 2018 | 08:42 AM
dapepper9's Avatar
dapepper9
You're going to want to have them inspected by a machine shop. Valve guides are often too tight.
Old Oct 24, 2018 | 08:48 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Thanks for the tip!
Any other parts I should look at replacing when I do the work? The distributor cap, wires, timing chain, and water pump all only have about 5k miles on them.
Old Oct 24, 2018 | 08:58 AM
1.7 ratio roller rockers? Hardened pushrods?
How far do you plan on tearing the motor down? Just doing top end? Or complete rebuild?
Old Oct 24, 2018 | 09:02 AM
1997JollyGreenGiant
I'll look into those when the time gets closer.
Just the top end. I'll probably do a full rebuild at some point in the future though.
Old Oct 24, 2018 | 11:36 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 1997JollyGreenGiant
I bet you would, but no can do. I only bought because it was a good price and I need heads for the truck. Outside of that, I have a wife, a kid, a mortgage, and a car payment on the wife's car.
The wife don't need that car!
Thanks for the tip!
Get the ported and polished to it will increase the flow even better! Can be down at the machine shop
Check the alternator and get it tested, and the crank seal.
Old Oct 24, 2018 | 11:39 AM
1997JollyGreenGiant
Yeah, I wish! But needed a newer safer car for transporting the kid.
Thanks! Alternator was rebuilt in the last 5k miles. Will check the crank seal though (should drop the pan anyway to check the pickup tube. Not having any issues, but been meaning to look at it).
Old Oct 24, 2018 | 11:40 AM
dapepper9's Avatar
dapepper9
Before purchasing all this, you mentioned the comp test and its readings. HOWEVER, do another. Both dry and wet tests. Pending how the wet test compares to dry, you might be dropping a G that is not going to do you any good.
Old Oct 24, 2018 | 11:42 AM
1997JollyGreenGiant
I did the test dry, and then wet. Numbers were pretty consistent between the two tests.
Old Oct 24, 2018 | 11:49 AM
dapepper9's Avatar
dapepper9
good good. I don't stop in here much anymore so wasn't sure if that had been posted before. But that points away from rings which is good. Could do a leakdown for S&G but that's up to you.
as for other parts, 2bbl m1/ airgap is a great pair with those heads if you can score the right deal. 1.7 rockers are ok too but unless the ones you choose have guideplates you don't need to worry about hardened rods
Old Oct 24, 2018 | 11:53 AM
1997JollyGreenGiant
Ok, good to know. I actually have a new M1 intake that I'm not using. Not sure if I will use it or not. With it being a heavy truck, I'd be a little concerned about how much torque I'd lose. Thanks for the tip on the rockers though.
