No start cranks only
Old Oct 27, 2018 | 11:35 PM
Grimace71's Avatar
Grimace71
Default No start cranks only
Getting a code 1389 having problems figuring out what I need to do to find true problem and fix ....the relay seems to be fine . Getting fuel getting spark .voltage dropped while driving I thought it was the alternator so replaced it but then the code came up I just recently replaced the fuel pump but its been messed up too running out of fuel with over quarter tank left any help is appreciated thanks
Old Oct 28, 2018 | 08:42 AM
No ASD voltage at PCM.
ASD relay is in the power distribution center under the hood, right behind the battery. With ignition On, you should see power on two pins in the socket. Are you getting it?
Old Jan 13, 2019 | 05:57 PM
dodgedude37's Avatar
dodgedude37
Default crank but no start
this post did not go to completion. i have a 93 stealth base, it also cranks with no start & no ck engine. while standing in front of vehicle with key on i will hear a clicking noise at rear of engine. after that car will start & run fine, i have removed & cleaned IAC valve. it acts like it is still sticking.
Old Jan 13, 2019 | 07:16 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
dodgedude37
I had a 93 Stealth TT AWD 400hp 4 wheel steering. Go over to this site for questions and answers, lots of nice people there:
https://www.3si.org/
