lost keys need new cylinder
Old Nov 11, 2018 | 11:22 AM
Jmikk's Avatar
Jmikk
Default lost keys need new cylinder
hey all! called a local locksmith today to get my keys replaced and he said $250. THATS INSANE!!!! hell i dont even know if the ignitions been replaced or not so i just want to replace my ignition, get keyless entry and call it a day. how do i replace the lock cylinder without a key? i gotta get this thing going, its a 1998 ram 2500 5.9 cummins.
Old Nov 11, 2018 | 12:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Idk if this truck will work on that new of a truck (it worked in my 86 Ram until I got a new cylinder), get a heavy duty screwdriver and a big hammer. Hammer it into the cylinder
Old Nov 11, 2018 | 01:01 PM
Jmikk's Avatar
Jmikk
should I be concerned haha! What’s the worst that could happen, I’ll try when I’m with the rig again if all else fails. Need to get my safety torx bits from work
Old Nov 11, 2018 | 05:14 PM
MoparFanatic21
I never had anything happen so I don't know to be honest lol. I assume you could break the mounts
Old Nov 12, 2018 | 03:55 PM
Go visit the dealer with your vehicle title in hand, and some variety of ID that matches the name on the title. The dealer can then pull the stock key codes for your truck, and cut you a key. Last time I had to do that, it was less than 10 bucks.
Old Nov 12, 2018 | 08:35 PM
primem's Avatar
primem
then celebrate that you don't own a ford...who don't keep codes past 10 years. cost me $170 at the locksmith and that was me removing the door lock cylinder to get 6 of the 8 tumblers.
Old Nov 12, 2018 | 08:55 PM
crazzywolfie's Avatar
crazzywolfie
you may end up having to replace the ignition switch with the cylinder. cheaper than a lock smith but still a bit inconvenient. as far as i know there is no way to swap out just the cylinder without the key. you can possibly take apart a door lock if they are the same and see about making a key that fits. very time consuming but cheapest route.
Old Nov 16, 2018 | 12:09 AM
primem's Avatar
primem
the problem is...ignition lock cylinders have 2 more tumblers than the door cylinder...so the locksmith would have to guess at the last 2. My locksmith had to cut 2 dummy keys until he found the correct match.
