turn key backwards radio works turn it forward nothing works
Hi,
I have a 1994 ram 1500 with a 5.2 V8. I just bought it a month ago. I drove it Tuesday with no issues. Tried to start it yesterday and nothing lights up or works when I turn the key to start. If I turn the key backwards the radio comes on but I have to turn the key all the way forward to get the radio to turn off and then nothing works again when I turn the key forward again. I changed the ignition switch today and that didn't help. I tried to install the new key cylinder I also bought but the lock pin is missing that locks it in the ignition switch and the cylinder won't lock in place so I need to take it back.
I just want to find out if I'm even doing the right thing. I can't find anything obvious like relays or fuses, loose or melted wires or anything like that. It can't be the starter because the radio and dash lights don't come on when I turn the key. Any advice would greatly be appreciated.
Thank you,
Steve
Thank you,
Steve
I took another look at the old lock cylinder and saw that it's broken on the end. The new cylinder I bought today doesn't have the locking pin that holds it in the ignition switch. The old cylinder has a hole that goes all the way through the outer cylinder so the pin can ride on the inner cylinder and move up and down. The new cylinder doesn't have a pin and the hole doesn't go all the way through to the inner cylinder. I'm guessing this is a bad part and I'll take it back for another one in the morning.
The cylinder came with the plate and screw but there's nowhere to install the screw on this one that I can find. The old cylinder has a pin in the cylinder itself that you need to push down to remove the cylinder from the ignition switch. The pin also rides up and down on the inner part of the cylinder when you turn the key. I'll try to send pictures when I get to my shop.
Trending Topics
Are you sure you have the correct lock cylinder? the design changed in 97 or 98, The plate and screw hold the cylinder in place. Biggest problem i had was the steering wheel lock, It was a pain to get everything lined up. Here is a video that may help...
