2nd gen performance
Old Dec 15, 2018 | 02:23 PM
Miguel Toro's Avatar
Miguel Toro
Default 2nd gen performance
Any recommendations on electric fans for my 2nd gen Ram?
Old Dec 15, 2018 | 06:35 PM
Ramman18's Avatar
Ramman18
There's a write up in the tech DIY section, but it's pretty custom what he did. I have read about people using Dakota fans or just generic and doing their own wiring.
Old Dec 15, 2018 | 09:31 PM
Yeah, Ford Taurus fans are about the right size, and move enough air. Just gotta wire it up.
Old Dec 15, 2018 | 11:46 PM
00t444e's Avatar
00t444e
Why, the clutch fan is more reliable and pulls more air, the slight bit of extra HP you get from switching to electric isn't worth it in my opinion. I am not sure about the Rams but in the Jeeps many people have had issues with it running hot after switching to electric fans.
Old Dec 16, 2018 | 09:35 AM
Gotta have enough fan for the job at hand. Most folks that I have seen having overheating issues after the conversion, simply didn't use a mean enough fan for the job.
Old Dec 16, 2018 | 10:23 AM
Moparite's Avatar
Moparite
I would have to agree if it's horsepower you are after. But if you still want an electric fan check out flexalite
This is like the one i have it will fit the width of out rams radiator perfect but it leaves a few inches at the top/bottom and it flows 5500 CFM of air.
https://www.flex-a-lite.com/electric...ll-shroud.html
Old Dec 16, 2018 | 01:55 PM
Spillage's Avatar
Spillage
I have dual e-fans, and even with one disconnected it wont run hot.... and my a/c is cooler.
So any complaints about overheating because of an e-fan installation cries poor equipment selection/setup.
Old Dec 16, 2018 | 02:10 PM
wca_tim's Avatar
wca_tim
What kind of a set-up did you use? If it's in a thread on here, sorry for being lazy... :-) Thanks! Tim
Old Dec 16, 2018 | 08:08 PM
Miguel Toro
Honestly l wanna get the electric fan since they clear up a lot of space in the engine bay easier to work on without that big fan shroud
Old Dec 16, 2018 | 08:10 PM
Miguel Toro
Thanks appreciate it
