Truck won’t start after sparking
Old Dec 21, 2018 | 04:12 PM
Chunx89's Avatar
Chunx89
Default Truck won’t start, BAD PCM?
I was fixing my coolant temp sensor wires just now, and they started sparking when they hit the alt. I disconnected the battery but unfortunately the terminals layed back onto the battery. Now the truck won’t start, and I’m getting “no link” in scanner. Pretty sure I burnt my ecm up...? Also the mileage says “no bus”
i checked all fuses only one that was blown was the “cluster” 10amp, replaced that and nothing still.
Old Dec 21, 2018 | 05:54 PM
DerTruck's Avatar
DerTruck
Very possible. If the coolant sensor wires touched the fat wire going from the alternator to the battery it did create an unfused +12V to ground (the sensor is read to ground). There are two fuses for the PCM, #3 under the hood and #9 in the inside panel. Also check the ECM ground wiring from the ECM to the front of the engine if a ground wire burned up.
Old Dec 21, 2018 | 06:14 PM
The two-wire sensor comes from/goes to the PCM. It's a five volt reference signal the sensor modifies, for the PCM to read. If you shorted that to the alt output, chances are REAL good you smoked the PCM.
Old Dec 21, 2018 | 06:18 PM
Chunx89's Avatar
Chunx89
Yeah it’s what I thought, where do I go about getting a new one? I see some online that I give vin and mileage to and they mail it already plug and play? Any experience with them?
Old Dec 21, 2018 | 06:21 PM
There is one vendor that is actually a sponsor here..... Though I don't recall their name just offhand. They have threads scattered about though. Give them a shot.
Old Dec 22, 2018 | 04:51 AM
Chunx89's Avatar
Chunx89
Well I ordered a new pcm, also found the pigtail for the coolant sensor, which wire goes where? Do any of you have a wiring diagram for it? Or does it not matter?
Old Dec 22, 2018 | 09:38 AM
You can download the factory service manual for your truck from this thread.
Old Feb 9, 2025 | 12:27 PM
Chunx89's Avatar
Chunx89
Old post but you don’t happen to remember the vendor do you? When I purchased this PCM it came with a lifetime warranty so possibility I bought it through that vendor!
Old Feb 9, 2025 | 12:48 PM
I don't think they are a sponsor here any more... I don't see their ad at any rate. I don't remember their name..... Can you go back thru your payment records to see who you bought it from?
