Looking for advice about reverse light bulbs for 98 ram
Old Dec 25, 2018 | 11:16 AM
20tprice's Avatar
20tprice
Default Looking for advice about reverse light bulbs for 98 ram
I have a 98 Ram 1500, and the reverse lights are garbage so I can hardly see anything. Was wondering if anyone has replaced these bulbs with leds and if so what is the bulb # and what is a good choice?
Old Dec 25, 2018 | 11:22 AM
HeikIlm's Avatar
HeikIlm
Led bulds are junk, get yourself couple of auxliary lights, and wire them via relay to reverse light switch.
Old Dec 25, 2018 | 11:36 AM
This. So much this.
Put some GOOD lights back there, so you can actually SEE what you are backing up into.
Old Dec 25, 2018 | 11:42 AM
I put LEDs in mine. Way brighter than incandescent.
Old Dec 25, 2018 | 12:47 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I have aftermarket housings with led bulbs, and a tailgate bar that lights up white when in reverse. Even with my tinted windows I can still see
Old Dec 25, 2018 | 01:47 PM
20tprice's Avatar
20tprice
is it significantly better? Like can u see more than 7 feet back?
Old Dec 25, 2018 | 04:09 PM
Never measured. I’m going by seat of the eyeballs feelz.
Old Dec 25, 2018 | 07:12 PM
HeikIlm's Avatar
HeikIlm
Here's my reverse light setup. First is just one 21 watt light:
Here is two 27 watt led-lights. I might change those spot lights to a flood-type lights, would be much more useful. These also have 3-position toggle switch; on with parking lights - off - on with reverse:
Then on a tight spots, I have 18 watt lights at the front corners of the bed. Lights nicely front and side area of the rear tyres:
Btw, picture doesn't do justice, there is much more light on those rear lights than it shows on a pic.
