Clicking noise under load
Old Dec 28, 2018 | 12:42 AM
cman9898's Avatar
cman9898
Default Clicking noise under load
hey guys nother problem 5.2 auto transmission I’m getting a clicking sound from the engine that only happens in gear with the throttle presses it does change tempo as the engine accelerates but stops when the throttle is released even if the RPMs stay the same. I’m also leaking transmission fluid from the front (aux trans cooler gone bad I think). The only code I’m throwing is 0441 wich is incorrect purge flow. Might have something to do with the lack of a canister... Local thought is values or injectors anyone gat any tests or experience with this issue?
Old Dec 28, 2018 | 09:33 AM
Spark Knock? Have you fixed your plenum yet? How old are your ignition parts? O2 sensors? How many miles on the truck? What year truck???
Old Dec 28, 2018 | 10:42 AM
cman9898's Avatar
cman9898
It’s a 1997 I don’t know what’s been done other than the o2 sensors new and not Bosch I’ve been told the motor was rebuilt but I can’t prove it and it drives me crazy so I’m not sure how many miles are on it plus it’s lifted with bigger tires and the sensor was never adjusted
Old Dec 28, 2018 | 07:33 PM
Still stock gears as well? Or did those get changed?
Does it sound like marbles rattling around in a tin can? Or different?
Old Dec 28, 2018 | 07:43 PM
racefan41's Avatar
racefan41
Did the code throw when the noise began? roughly...
Old Dec 28, 2018 | 08:15 PM
cman9898's Avatar
cman9898
Update just did spark plugs and found no difference although a couple of the plugs white crust on the side of the hanger
Old Dec 28, 2018 | 08:16 PM
cman9898's Avatar
cman9898
The code has been around for a while and not marbles more like a metronome
Old Dec 29, 2018 | 08:57 AM
Could you post an audio file by any chance??
Old Dec 29, 2018 | 11:01 AM
cman9898's Avatar
cman9898
I can’t get it isolated enough for an audio file
Old Dec 29, 2018 | 12:08 PM
cman9898's Avatar
cman9898
So I cracked the valve covers today and the fourth rocker in is loose and shifting more information to follow
