Spark & fuel / No start
Hi everyone. Looked everywhere I could for a similar issue and couldn't find any. Will leave a To Long Didn't Read (TLDR) at the bottom for anyone who doesn't want the long winded story.
Anyway...
99 Ram 1500 5.2 Laramie is the truck. Went to start my truck last night to go out for the night and wile it was idling it died on me. Idle was rough but I have had a intermittent rough/low idle since I bought it and never thought anything of it. Never stalled before even wile being left unattended warming up in the AM. Vehicle has not restarted since but will crank. Their is spark and we can hear the fuel pump running / the smell of gas is noticeable wile attempting to start so we reasonably assume it's moving fuel properly. We have changed the IAC valve out and have changed the ADS relay as well. We attempted to start the vehicle with starter fluid with no luck. Check engine light does not come on when key is turned to "on" position. Check engine will only come on when it's attempting to fire but after it's cranking for a bit that also goes away. Any suggestions will be appreciated as we are at a loss except for a few other ideas read about online
TLDR: has spark, appears to have fuel. Turns over and only check engine light is wile cranking. Changed ADS relay and IAC valve.
Anyway...
