P0443 Purge Solenoid Circuit
Old Jan 3, 2019 | 02:08 PM
ThomasF's Avatar
ThomasF
Default P0443 Purge Solenoid Circuit
2000 Ram 5.9 Magnum
Have replaced solenoid. Diagnosing the connector, I am getting 12v from the Ign wire to ground with key on, and getting 6-8v from the Solenoid Control Wire to ground. Continuity is good from the Solenoid Control wire to pin 20 in the ECM plug. Confirmed good connections at the solenoid by disassembling the connector and manually placing the female onto the male pins of the solenoid.
Not real sure what else to try at this point and unsure what I am suppose to be seeing voltage wise from the computer to the solenoid.
Thanks!
Old Jan 3, 2019 | 02:31 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by ThomasF
2000 Ram 5.9 Magnum
Thanks!
I had this same code that can up twice on one trip. I disconnected the battery for 10 minutes and it never came back. Did you check the lines going to it?
Old Jan 3, 2019 | 02:53 PM
ThomasF's Avatar
ThomasF
Thanks for your comment.
I have inspected everything and it seems to all be fine.
The code does not indicate a leak but rather a circuit malfunction. Open or shorted to ground.
I suspect a questionable ground or bad splice somewhere.
Old Jan 3, 2019 | 07:13 PM
MoparFanatic21
It could be. Download your service manual from the FAQ section wiring diagrams are in section 8W
Old Feb 24, 2019 | 04:21 PM
ThomasF's Avatar
ThomasF
Still dealing with this code.
I tested and confirmed the solenoid is good.
Confirmed 12v+ on the blue wire.
Confirmed continuity on the pink wire to pin 20 on the connector.
I believe I have a failed driver in the PCM. I used an advanced scanner to manually open and close the solenoid through the computer and it doesn't respond to the computer commands.
One question though, can a PCM driver be intermittent? At times, the valve will work for just a few moments. I have confirmed this on multiple occasions but it will never stay working. This led me to believe there was a short in the PCM signal wire but continuity and tracing says otherwise.
Old Feb 24, 2019 | 04:58 PM
Yeah, that's a failing trace on the PCM circuit board. Time for a new one.
