46RE trans
Old Jan 23, 2019 | 12:31 PM
Ramchu's Avatar
Ramchu
Default 46RE trans
I been looking for a transmission for nearly a year at a reasonable price to rebuild for my truck.
Recently 2 have popped up on craigslist in my area.
The 1st is a 46re out of a 96 4X4 with 144,000 miles for $400.00
The 2nd is a 46re out of a 98 4X4 for $225.00 mileage is unknown.
What I have in mind is a total rebuild, no matter which one I buy, naturally I would prefer the cheaper of the two.
If I go with the one out of a 1998, will I run into any problems trying to use it in my 1996 ?
Old Jan 23, 2019 | 03:31 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No but you will need to use the internal wiring harness and throttle body from your 96 transmission
Old Jan 23, 2019 | 04:06 PM
Ramchu's Avatar
Ramchu
Ok, I get using the internal wiring harness .
I didn't know a 46 RE transmission had a throttle body.
Old Jan 23, 2019 | 04:45 PM
MoparFanatic21
My bad!! I meant valve body lol the retainers for the sensors are different
Old Jan 23, 2019 | 05:26 PM
Ramchu's Avatar
Ramchu
I thought that I read, that they changed the how the 4X4 shifter mounted in 98,
something about moving it from the transmission to the body.
Is that correct or not ?
Old Jan 23, 2019 | 06:48 PM
Yes, it is, 97 and older, the trans has the bosses for the shifter mount. 98 and up won't have 'em.
Ideally, you need a trans from a 96 or 97 truck. If you are going to rebuild it anyway, doesn't really matter if it works or not, so long as the case is in good shape, you'll be golden.
Also, the trans needs to come from a truck with the same number of drive wheels. 2 or 4 wheel drive transmissions are not precisely interchangeable.
Old Jan 23, 2019 | 07:33 PM
Ramchu's Avatar
Ramchu
Thanks HeyYou
Old Jan 24, 2019 | 10:55 AM
MoparFanatic21
See I also forgot about the speed sensor provision. Didn't know about the 4wd drive shifter did know the pattern was different. What is the mounting difference? Glad you chimed in before I had the guy but the wrong trans!
Old Jan 24, 2019 | 04:22 PM
On the 4x4 trucks, the VSS is on the tailhousing of the t-case. If you are using the original case, then that bit doesn't matter.
Yup, shift pattern on t-case also changed, and the 98 and newer t-case won't have the provision for VSS. There is no good workaround for that I am aware of.
97 and older trucks, the t-case shifter bolts to bosses on the trans, 98 and up, the shifter bolts to the body, and the bosses on the trans are probably not there. The newer the trans, the less likely they will be there. (on 99 and up, I would not expect them to be there, ever..... )
Old Jan 24, 2019 | 11:03 PM
MoparFanatic21
Well this just bad switching to the factory cab more interesting lol
