Cluster gauge lights/parking lights out
Old Feb 1, 2019 | 07:33 PM
Scott Blackford's Avatar
Scott Blackford
Default Cluster gauge lights/parking lights out
first post here. first time owning an older cummins. 98 12v. 2500 sport, 188k miles.
Headlights work, Cluster gauge and parking lights work but when I pull the headlight switch all the way out, the headlights work, cluster gauge and parking lights are off. at some point in the pull, the cluster gauge lights flash on. I can toy with the position of the lights and get the cluster gauge lights on but not while the headlights are on.
I added headlight relays as many of the forum posts suggest. I replaced the dimmer switch on the steering column as other posts have suggested. I changed the headlight switch harness and I swapped out the headlight switch 6 times. I can't find any sign of burned wires or any indication of a problem. I have not checked the grounds but if a ground was poor I would think I'd get different behavior. The lights on the cluster gauge when I hit the right position are bright and don't flicker. To me, it still points to a headlight switch-related problem. But after the 6 replacement with the same results, I'm too close to the problem and need some insight from others.
Any thoughts?
Old Feb 1, 2019 | 08:19 PM
There was another thread not so very long ago, with the same problem. Lights only worked with the headlight switch in just the right position...... that member went thru a bunch of the same stuff you did, but, I do NOT recall what the actual fix was. You should be able to find that thread with a search...... (use google, and put site:dodgeforum.com in the search bar as well. Google is a much more effective search engine, than the search feature here.) I am pretty sure the thread was last year some time..... but, may be as long as two years ago.
Old Feb 1, 2019 | 10:46 PM
DerTruck's Avatar
DerTruck
The headlights and the parking/dash lights are on separate circuits which have separate power feeds (separate fuses too). Did you check that both the red/white (B1 connection) and pink/red (B2) wire have power ?
Old Feb 2, 2019 | 01:39 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That was me I'll link the thread, here it is.
https://dodgeforum.com/forum/2nd-gen...ch-issues.html
Old Feb 2, 2019 | 09:40 AM
Thank You.
Old Feb 2, 2019 | 01:38 PM
MoparFanatic21
Thank You.
You are welcome just glad my threads will finally help someone
Old Feb 2, 2019 | 10:03 PM
Scott Blackford
Thank you. I'll check it out and let you all know what I find.
Old Feb 3, 2019 | 08:44 AM
Moparite's Avatar
Moparite
What brand headlight switch did you put in and did you use the same brand each time? I had a similar issue but the main problem was the switch. Auto zone junk! Got a new switch and pig tail from RA and the problem hasn't been back. Also if you are not aware there was a TSB on the headlight issue for the 3500's. The 2500's should have been included because they have more lights(load on the switch) than a 1500 but not as many as the 3500's but still experience the same problem. To help keep the load off the switch it helps to install some LED lights(marker & clearance).
http://dodgeram.info/tsb/recalls/819.htm
