No bu5 when Can bus is plugged in
Old Mar 4, 2019 | 06:54 PM
  #21
Matthew_P's Avatar
Matthew_P
Okay . How do I go about doing this when it goes to the wiring. Do I keep the current CTM wires and add new ones for the white connector?
Old Mar 4, 2019 | 08:43 PM
  #22
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
unfortunately you would need a new dash harness. Let me look into this tonight just to be sure
Old Mar 4, 2019 | 08:50 PM
  #23
MoparFanatic21
Looking at the diagram the Bus wires should go straight to it and only use the ctm if you have the factory alarm. Check the CCD +/- wires from the pcm to the joint connector and then to the overhead console.
Old Mar 5, 2019 | 02:47 PM
  #24
Matthew_P's Avatar
Matthew_P
Is this the wire diagram with the CTM with one plug or 2 plugs? My truck doesn't have a key fob security system, so does that mean that mine doesn't need a different CTM?
Old Mar 5, 2019 | 05:31 PM
  #25
MoparFanatic21
you would be correct the only time you need the 2 plug ctm is if you have the alarm system just to be sure tonight I'm going to see what the ctm controls. But if it is saying "No Bus" then that means those wires in the diagram are bad somewhere or the console itself
Old Mar 6, 2019 | 08:26 PM
  #26
Matthew_P's Avatar
Matthew_P
I'm going ahead to buy a second wire harness for the overhead console. Whether the connector is unplugged or plugged in it still won't dim.
Old Mar 6, 2019 | 10:12 PM
  #27
Matthew_P's Avatar
Matthew_P
That tells me that it has to be the cab harness that runs to he console.
Old Mar 7, 2019 | 01:20 AM
  #28
MoparFanatic21
could be
Old Mar 8, 2019 | 06:09 PM
  #29
Matthew_P's Avatar
Matthew_P
Is there anything else that controls the dimming to the console? I don't think so but I don't know for sure.
Old Mar 8, 2019 | 07:31 PM
  #30
MoparFanatic21
Other then the switch itself no lol
