No bu5 when Can bus is plugged in
Old Mar 10, 2019 | 12:54 PM
  #31
Matthew_P's Avatar
Matthew_P
Just for recap when the Ccd connector is plugged. The ABS light, and airbag light come on, followed by the Engine light with No bu5.
Old Mar 10, 2019 | 01:11 PM
  #32
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
so adding another load to the CCD bus wires causing 2 other CCD bus wires to throw a code. I would say either bad CCD wiring somewhere or bad PCM
Old Mar 10, 2019 | 05:49 PM
  #33
Matthew_P's Avatar
Matthew_P
Would it affect the radio as well because the radio still was functioning.
Old Mar 10, 2019 | 07:34 PM
  #34
MoparFanatic21
It shouldn't affect the radio
Old Mar 12, 2019 | 04:11 PM
  #35
Matthew_P's Avatar
Matthew_P
for the head light switch, when it dims, would it be an all or nothing concept? (Radio, gauge cluster, and Overhead)
Old Mar 12, 2019 | 04:58 PM
  #36
MoparFanatic21
should be all or nothing unless it didn't light up to begin with
Old Mar 12, 2019 | 05:20 PM
  #37
Matthew_P's Avatar
Matthew_P
Okay, The console did dim before, at the time the harness was not put in the dash. Also worked the 1st day after I drove it home along with the CCd working.
Old Mar 12, 2019 | 08:32 PM
  #38
MoparFanatic21
Check the wiring or you're console somehow went bad
Old Mar 15, 2019 | 07:38 PM
  #39
Matthew_P's Avatar
Matthew_P
Background : the wire harness has 2 connectors, 1 brown plug, and one white plug for Ccd. I got the new harness today, I plugged in the Ccd plug (white): Gauges went to their proper positions, and no problems occurred. However the brown plug wasn't connected, because the other one was plugged in. Does it need to be plugged in for the test to be valid?
Old Mar 15, 2019 | 08:13 PM
  #40
MoparFanatic21
Post pictures of the back of the console and the plugs for me
