Blend Door Actuator
Old Feb 23, 2019 | 10:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Blend Door Actuator
The blend door actuator is cable operated on a 94-97 Ram and electric on a 98-01 Ram right?
Old Feb 24, 2019 | 09:24 AM
Electric showed up in 2000. 99 and older are cable operated. (I think late production 99's have the electric as well, but, not 100% sure on that.)
Old Feb 24, 2019 | 10:21 AM
Ramman18's Avatar
Ramman18
The new dashes got the motor somewhere in 98 I believe. My early build 99 has the motor. SHouldn't be hard to tell - the motor has zero resistance when turning the temp and you can hear it whirring.
Old Feb 24, 2019 | 03:52 PM
MoparFanatic21
Thanks guys! Had a problem with mine because the PO was...well there aren't any nice words I would say and was going to the junkyard to get the right one but it didn't work out lol
Old Feb 25, 2019 | 10:42 AM
Ramman18's Avatar
Ramman18
The 98 dash is a unicorn as it was only run one year. It's weird what happened at Dodge design versus engineering. They designed a completely new interior to be used with dual air bags and the quad cab but decided some dash components weren't good enough. The final tweaks to the 99-02 were all the same but whether the blend motor showed up in 98 sometime or 99 with the final touches is unknown to me. They continued to make software tweaks in 2000 and beyond plus mechanical changes as well. In my studies, it is hard to find any two years of production that were identical. Something is always getting tweaked.
Old Feb 25, 2019 | 01:19 PM
MoparFanatic21
I agree with you there. From what I gather (none of my books mentioned the blend door) is 98 cable operated, 99-01 electric motor, and some 2002 (2500/3500) full electric controls no vacuum.
Old Feb 25, 2019 | 09:37 PM
Ramman18's Avatar
Ramman18
Interesting, never knew 2002 HDs had a different system. Been awhile since I've seen a thread at a diesel forum about wild vents. I guess the 2002 is the holy grail then, as the 2003 3rd gen had all kinds of blend door and HVAC issues. We really don't have it that bad. 3rd gens had just as many issues and 4th gens have other issues. I suppose the mantra of auto makers is "never learn from the past." Either that or they're really stupid.
Old Feb 25, 2019 | 10:49 PM
MoparFanatic21
I believe it's the money and them not speaking English
