Headlights turn on and off while driving
Old Feb 24, 2019 | 11:51 PM
Cam Daniels's Avatar
Cam Daniels
Default Headlights turn on and off while driving
So I have a 1994 2500 and the headlights will randomly turn on and off, I have replaced the headlight switch and that didn't do the trick. What do I need to do? Thanks
Old Feb 25, 2019 | 01:23 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What type of headlights do you have? 2 bulb or 4 bulb?
Old Feb 25, 2019 | 01:59 AM
Cam Daniels
They are just the stock headlights. Could I replace them with led headlights? Would that help because its crossed my mind
So I did some what of a test tonight and I only had my low beams on for a couple hours and was just fine. Then I turned my brights on and they lasted a few minutes then started turning on and off. Then I switched back to my dims and they did it 3-4 times then stopped.
Old Feb 25, 2019 | 03:34 AM
MoparFanatic21
Sorry missed the year. You could but I believe you have a wiring issue, which changing the headlights won't work. Check the power and ground wires for your headlights. I would probably bet on a ground issue.
Old Feb 25, 2019 | 05:16 AM
Cam Daniels
I'll scope it out better in the morning and chime back in tomorrow night and let you know. Thank you
Old Feb 25, 2019 | 01:58 PM
Moparite's Avatar
Moparite
Read the TSB/recal! It should have included the 2500's also due to the extra lights that cause more amp draw. Look at your connector on the headlight switch, Bet it has one or more heated or melted terminals. This was the case with mine and you need to replace connector also(available at RA).
http://dodgeram.info/tsb/recalls/819.htm
Old Feb 25, 2019 | 10:05 PM
Cam Daniels
what connector should I get for it? They have 3 if them
Old Feb 25, 2019 | 10:50 PM
MoparFanatic21
The main headlight plug it looks weirdly shaped
