Plenum gasket question...
Old Feb 27, 2019 | 11:36 PM
  #31
2bit's Avatar
2bit
Get copper plugs for it. I prefer NGK. I've had really good results with Standard Motor Products ignition parts from Rock Auto. Don't let a local parts store sell you BWD, it's complete junk. I used Felpro gaskets on my truck. I just ground the ends off the plenum bolts and reused the steel plate. I tore the gasket between the timing cover and oil pan when I did the timing chain, so I had to drop the oil pan. Search for "95 oxidizer special" I have quite a few pictures in that thread.
Old Feb 27, 2019 | 11:42 PM
  #32
2bit's Avatar
2bit
Don't move the distributor! The ignition timing is completely controlled by the ECM. Turning the distributor adjusts fuel sync (timing of the fuel injectors). That's why I recommend the timing chain. If it's loose, it affects your ignition and injection timing.
