2002 Headlight Issue
Old Mar 1, 2019 | 02:12 PM
Originally Posted by ranger140892
Yep, The LMC kit is nice. I've used it on my dentside Fords and Jeeps. However, for the Sport headlights, it didn't do all I wanted it to do. It doesn't make all four bulbs light up on low beam, which was my main desire. Compared to my dentsides and jeeps, the stock second gen Ram headlights are like 1948 Rayovac flashlights.
I also installed new housings, and better bulbs. It was a MAJOR improvement from the yellowed stock lenses, and old bulbs.
Old Mar 1, 2019 | 02:25 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Upgrade to HID and you'll be even more impressed
Old Mar 1, 2019 | 02:30 PM
DerTruck's Avatar
DerTruck
Does the high beam indicator come on ? If so the switch is good. If the bulbs test ok too (ohm meter) then it's somewhere in the wiring.
Old Mar 1, 2019 | 02:38 PM
Podge's Avatar
Podge
Yes the blue high beam indicator comes on for both high beam and 'flash'.
Old Mar 1, 2019 | 02:55 PM
ranger140892's Avatar
ranger140892
I did that also
Old Mar 21, 2019 | 10:59 AM
Podge's Avatar
Podge
Guys, just thought I would give you a quick update.
Ordered a new switch/stalk and fitted it. This cured an intermittent hazard flasher issue but not the headlight problem.
I then removed both bulbs to take an even closer look and on initial inspection all seemed fine but after testing them it appears they had broken down and so I replaced them and now all works well !
Just goes to prove it's not always that bad...
Thanks for all your help and suggestions.
