2001 transfer case question
Old Mar 2, 2019 | 12:29 AM
01DodgeBaker's Avatar
01DodgeBaker
Default 2001 transfer case question
2001 Dodge 5 speed 5.2 4wd
I have a 01 Dodge ram 1500 regular cab short bed. With the 5.2 and 5 speed manual. My transfer case tries to slip into neutral while coasting or high rpms. I have researched and found that I think I have nv231d or np231d and was wondering if transfer case out of an automatic would work or not.
Old Mar 2, 2019 | 09:11 AM
Welcome to DF!
There are some minor differences in the input hub between manual, and auto transmissions, would it work? Possibly. I know finding a truck with a manual trans is difficult, at best.... Could try rebuilding your current case. Not that much goes into it.
Moving this to second gen ram section for ya.
Old Mar 2, 2019 | 11:11 AM
2bit's Avatar
2bit
SKF STCK231EE Info
231 (Only 3 Remaining)$104.79Add to CartSKF STCK241CC Info
241 Std. Duty (Only 1 Remaining)$130.79Add to CartSKF STCK241DD Info
241 DHD (Heavy Duty) (Only 1 Remaining)$167.79Add to Cart
And get a Gilly's Transfer Case Saver
Old Mar 2, 2019 | 02:45 PM
01DodgeBaker
Default Transfer case
I disassembled the rear tail output shaft cover and my snap right and everything looks fine. I can put it in and out of 4wd nust fine no hesitation it's only when I'm letting off the gas while in gear it wants to slip into neutral the transfer case shifter that it.
Old Mar 2, 2019 | 03:09 PM
Probably the nylon pads on the shift fork are worn out/gone.
Old Mar 2, 2019 | 04:01 PM
01DodgeBaker
Yeah that's one problem I was trying to avoid thinking about. Lol do you know or have a list of all dodges that transfer case might have came in from factory. I'm trying avoid rebuilding mine untill I can get a replacement then rebuild it then. I've also thought about unhooking the 4wd if possible right now I have a bungey cord holding shifter from moving
Old Mar 2, 2019 | 04:38 PM
Any 231d 98 or newer, that came behind a manual trans. (just to be safe.) Ram 1500s, and Dakotas, I think will be your best source.
Old Mar 2, 2019 | 05:36 PM
fj5gtx's Avatar
fj5gtx
manual transmissions don't last long in the jyards I frequent.... I saw one in a fresh to the yard 95 3/4 ton, went back a couple days later and it was GONE.
Old Mar 3, 2019 | 11:48 AM
Sheriff420's Avatar
Sheriff420
Call these guys http://www.mintonmotorsinc.com/home.html
