Clunk noise while driving?
Old Mar 12, 2019 | 07:07 PM
Austin_McK's Avatar
Austin_McK
Default Clunk noise while driving?
Hi guys, I have a problem with my 2001 Dodge Ram 1500, with the 5.2 Magnum in it. My problem is while I'm driving I tend to feel a big clunk once in a while. It usually is when I'm going 40 mph and above, never below. While driving I'm at a steady rpm and out of no where a big clunk will sound off and it never drags the rpm down or anything else. It has been more recent and I would like to get it fix. Im sure its a transmission issue, due to it not affecting the engine's rpm while driving. Looking for help if anyone knows of the problem. Thank
Old Mar 12, 2019 | 07:20 PM
2 or 4 wheel drive?
Old Mar 12, 2019 | 10:05 PM
Austin_McK's Avatar
Austin_McK
It is 4 wheel drive.
Old Mar 13, 2019 | 10:45 AM
U joints?
Old Mar 13, 2019 | 12:12 PM
potentshadow's Avatar
potentshadow
U joints?
I have seen a video of that. The clunking that is. I hear the U joints are major PIA to replace. Lots of beating.
Old Mar 13, 2019 | 12:21 PM
Bigger hammer makes it easier.
Old Mar 13, 2019 | 12:50 PM
HeikIlm's Avatar
HeikIlm
Does the clunking happen on what kind of road surface? On two wheel drive or four wheel drive?
Old Mar 13, 2019 | 12:54 PM
HeikIlm's Avatar
HeikIlm
Nah, just a couple of correct size sockets and a moderately sized hammer is all you need. After you've done it few times it's easy. But first time takes some practice to get used to method
Old Mar 13, 2019 | 02:12 PM
Austin_McK's Avatar
Austin_McK
The clunking happens on just normal paved asphalt road, but as said before it only happens when going 40 mph and above. I’ll have to check the u joints. But I’m pretty sure it only does it at 4th gear, but weird things is rpm doesn’t drop at... 🤔
